メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
3338の回答 すべて表示
New battery not charging
I replaced my battery with new. All went well, plugged in charger and apple display went on for a moment and then out. Reconnected the new battery thinking maybe I had not fully connected it. Same result. Reinstalled the old battery and the phone starts as usual and charges and remains on after charger is disconnected. Reinstalled new battery and again no progress. Is this new battery bad? I have left it to charge quite a while 15-20 minutes and still no apple start-up display. If I disconnect the small cable and reconnect it sometimes but generally not, the apple logo will come on, but only for a few moments and then it disappears and that's it. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
Probably a faulty battery.
による
Update,
Ifixit.com sent a new "replacement" battery and that did the trick. Great customer service and response. Once installed the battery showed a 40% charge. Followed packaging advice and allowed the phone to discharge the battery to 10% and then recharge to 100%.
All good at this point.
による
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
2回答
最も参考になった回答
Faulty battery, buy a new one. Just know your phone is 4 years old and no longer in production, so the batteries aren't either and most likely the ones you buy are cheap knockoffs, or the real deal that haven't been charged in 3-4 years.
この回答は役に立ちましたか?
スコア 2
コメントを追加
Well, I'm not so confident in that idea, since the battery was recently purchased directly from this site.
この回答は役に立ちましたか?
スコア 0
コメント:
Then I'd contact iFixit for a replacement then.
による
コメントを追加
回答を追加する
flywheel さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 129
