メインコンテンツにスキップ
Why is the battery light flash but won't charge and turn on?
Hi! So the power button lights up but the screen is black. I plug the charger in but the battery light just blinks orange. Not sure if its the charging port,the charger or the laptop. Is it an easy fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I would first measure the charger with a multimeter and see if you get the correct voltage. Then measure the amount of amps the laptop is drawing from the charger. Because the battery light responds when you plug in the charger it is unlikely that the charge port is bad. What I am guessing is that the charging IC is bad, if you know the charger is good. To verify, you will want to insert a charged battery and see if it powers on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 3,333
