Just spins when trying to start
All it does is spin when trying to start it
Spins as in no compression.... Probably bent valves due to jumped timing chain or failed belt drive depending on type of drive your valve train uses (I have no way of knowing what model or age of Honda product you are referring to). My crystal ball is in the shop too, go figure.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 100
@rickbeenken1961 do you mean that it just turns over but does not start? What model is your Honda? What have you checked?
oldturkey03 さんによる
@rickbeenken1961 do you mean the starter spins without engaging and turning the motor over
Jimfixer さんによる
