メインコンテンツにスキップ
The Blade ZTE E is an Android platform smart phone released in 2013 (Model: V956).
30回答 すべてを表示
Phone won't turn on or charge at all!
Few days ago I found my phone off in the morning. I put it on charge for whole day, but it won't turn on. When I try charging it (using it's own charger) , the charging indicator shows up, but percentage stays at 0%. I tried charging it using PC, but in vein.
I tried using an external battery charger. Even if I charge the battery to 100%, it drains to 0% withing 5 minutes and turns off.
The repair shop I took my phone to assumed it has a problem in charging IC(since they said there's no problem in battery) and changed it, but it didn't help either.
Normally if I press the power button, the display screen somewhat glows up, but remains black and won't turn on.
Please help me. TIA!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
2件の回答
最も参考になった回答
My dad have a ZTE phone but it won't turn on and when he puts it on the charger its turns
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try to bend the charger when its in the phone. Not that it bends but its tilted a tittle in the phone.
My sister had the same problem with a iPod and it charged with this trick.
Try another charger
And if you can take out the battery and make sure the metal contacts are clean of dirt or debris.
If you still cant get it to work take it to a repair store that is trustworthy. Be aware this may take days to a week to fix.
But you can just get a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arya さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,670
