メインコンテンツにスキップ
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
47回答 すべてを表示
Won't turn on with/without plugged to AC charger
Hi, my speaker does not turn on, when it is plugged to the AC I'm able to see the battery light but it won't turn on with or without be plugged to the power adapter.
I already updated its firmware but it did not work.
Please help !!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
I just had this problem. Did some searching and came across this: update.bose.com/soundlinkcolor to update my SoundLink's software. If that doesn't work (or if your unit's software is up to date), do the following:
1. Plug SoundLink's in to wall charger
2. Hold down the play/pause button for 15 seconds.
3. Then, BEFORE releasing the play/pause button, unplug the charge cord from the unit.
4. Release the play/pause button.
5. Plug the unit back into the wall charger.
6. Press the power button, and your unit should power on.
Side note: Steps 1-4 above put the unit in "ship mode" and steps 5-6 take it to 'normal mode'.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Not working
It is not working when I plugged in to my charger
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
arturorv00 さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 10
過去 30 日: 36
今までの合計 8,711
