Titebond glue for iPhone 6 frame to glass?
Well, I repair phones, but when I replace the iphone 6 screen. The frame always comes off the glass. I tried crazy glue but it didn't work. I read online and they say use Cold Press Glue. Well i went online and bought Titebond glue. I was wondering if anyone could tell me if i could use it to glue the frame back on. And if there is any better glue please tell me.
1件のコメント
If the frame keeps coming off the glass then you are using screen replacements that use hot press glue which the adhesive in result is weaker causing the screen to come off the glass after some time of the phone being used or even easily.
Why is hot press glue done screens cheaper? Because it bonds a lot faster and is cheaper to do. Better to get the screens that cost like 10%-20% more that use CPG (Cold Press Glue) technique as that is a lot better and you wont get that issue with the glass separating from the screen frame easily.
Also the screen frame being used has an impact on the assembly of the screen as low quality frames make it easier for the adhesive bond to separate.
Ben さんによる
