My tail light only turn on went I step on the breaks
My Odyssey 1997 the tail light only turn on when I step on the brakes
@adrianvane make sure that you have the proper light bulbs and that the contacts line up properly. If your light bulbs are proper than you need to check the wiring, most commonly at the housing, for short circuits.
このアンサーは役に立ちましたか?
@adrianvane Check the fuses and relays as well
I would try putting it into recovery mode and reinstalling iOS. Otherwise, you may wayt to jailbreak it. I heard the RedSnow just came out with an updated Honda release.
このアンサーは役に立ちましたか?
lmao how bout just telling them that they posted in the wrong category?
I guess you need to be certified iFixit MasterTech to enjoy making fun of other peoples minor mistakes. Great job, be proud of yourself.
eh....I was having fun. Relax my friend.
Also, I didn't know that me being certified showed up on here.
Yup having fun at other people's expense is really professional.
Are you guys here to help?
The iphone 5s answers forum is the wrong place to be asking about your odyssey 1997.
このアンサーは役に立ちましたか?
Ethan Chow there is no "iphone 5s answers forum" on here. The OP may have chosen the wrong device but is asking a legit question. There is absolutely no reason to be rude and issue a downvote based on that.
How was I being rude? I just pointed out that they were asking this question in the wrong section and would get better results if they put it in the correct section/ device.
First off, this is the right section. There is only one section and its "Answers". The OP just selected the wrong device image. You are missing the second part of that "issue a downvote based on that", which is apparently what you like doing throughout "Answers" .
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 147
