メインコンテンツにスキップ
耳全体を覆うフルサイズのヘッドフォン、通称サーキュマル・ヘッドフォンの修理ガイドとサポートです。
108回答 すべてを表示
JBL Synchros E50BT Broken Charging and Audio Port
JBL is wireless but also can be used using a wire, and I dropped it, with the wire on and broke the charging and audio port now I cant charge it anymore. can you help me fix it? :(
Update (07/02/2016)
my broken charging port looks like this
and the normal thing should look like this :/
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Have u fixed it? And how?
さんによる
I have disassembled the left ear speaker and have pictures and can take measurements of the 2.5mm jack. There is a 4 pin plug which has leads from the jack PCB board, blue, red, green, white. The PCB holds the jack socket and is mounted to the ear housing with 2 small screws. The jack socket is SMD mounted with 5 pin pads - 2 at the top flanking near the insertion, 1 left middle, 1 bottom right, 1 bottom center. https://i.imgur.com/tVm45Bv.jpg
I am going to call JBL to find out if I can obtain the replacement PCB.
さんによる
コメントを追加
9件の回答
最も参考になった回答
The part you need is: SA-HM14PA0300-B
That'll get you the small PCB with the charging jack (new part).
Costs ~ $9 + shipping
Call JBL Tech Support @: (800) 336-4525 (also on JBL support website - link below)
Last I checked they still had a couple in stock.
Note: You'll need to de-solder/re-solder the wires back to the replacement part, so find help if you don't have soldering experience.
https://www.jbl.com/support-product.html
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
We need the picture of other side
さんによる
コメントを追加
If you can open it up and find what perhaps the pad pattern and jack should look like, possibly you can find the same piece on AliExpress and then buy it and resolder it on. it involves surface mount soldering though, most likely.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my jbl e50bt broken
length adjusting part is broken
what i do now?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey, first of all you will need to open it. I recommend you to go to this video link to learn how:
https://www.youtube.com/watch?v=1CMVoqfh...
Very helpful for the issue. And be careful with the pins... so tricky!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Charging cable problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
https://www.ebay.ie/itm/362477615693?ssP...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
does this work?
さんによる
コメントを追加
hi
i need to replace the head band due to a repair agent ripping it is this possible
Cheers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have JBL headset but I cannot locate the charging port so I need help
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The charging port is the same port used by the 2.5mm jack on the left ear side. It uses a USB Type A to 2.5mm male jack supplied cable. If you are missing that cable, you should be able to get a replacement from JBL.
さんによる
コメントを追加
I have JBL headset but I cannot locate the charging port I need help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jkradi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 7,192
