メインコンテンツにスキップ
Released March 2006, identified by model D620 on the keyboard bezel.
39回答 すべてを表示
Dell laptop won't start!
I have a Dell latitude d620 and sometimes when i press the power button the three keyboard buttons are flashing and nothing else happens! no signal at the lcd, no nothing! Any ideas?
Update
i forgot to say that sometimes it starts up correctly... i read about damaged cpu or motherboard but it works nice when it opens...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 16
2 件のコメント
My laptop only 2 lights blinks but it wonts get started
さんによる
I have this problem with dell latitude D620, when the adapter is removed while on battery the system will boot but immediately I plug on adapter the system shut down. What can I do to solve this problem.
さんによる
コメントを追加
11件の回答
ベストアンサー
One of the memory modules could be bad.
Dell Latitude D620 has hidden memory module under the keyboard.
Try removing memory modules one by one.
このアンサーは役に立ちましたか?
スコア 8
1件のコメント:
Thank you for this disassempling tutorial with pictures :)
さんによる
コメントを追加
Sounds like the RAM chip under the keyboard is not seated to suit itself. If you've never done this before, refer to the Tear Down photos before you try it. If you are all thumbs, bring it to somebody.
After unplugging the AC adapter and removing the battery, you might try taking the keyboard off, disconnecting the cable and removing inspecting and reinstalling the RAM chip.
If it springs up when you release the clips, remove it and inspect the buss. If it looks clean and smooth, reinstall it by carefully pushing it gently into the socket at the release angle. After you feel it seat slowly push it down. If the clips snap around the base, you should have it seated.
Reassemble the keyboard cable being careful to get the tie down clip and the wire handle down flat. Replace the keyboard, and the battery and AC adapter and fire it up. You should get a message telling you that the RAM has been removed. press the F1, and the boot should kick windows on.
Good luck!
good medicine
Update
Should have thought of this!
If you lay a piece of paper on the screen, after you unseat the keyboard, you can lay it on the paper and save yourself the hassle of unplugging the screen cable! Don't scratch that screen.....
Good luck!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for your help! I tried this as you said but sometimes it won't open the same as before... i can not understand this machine. It will open i will work some hours (some times it works for days..) and it will stop... :/
さんによる
thanks yesterday I was worrying today thanks to this remark I smill
さんによる
コメントを追加
I have an E6420 which would not boot up past the Dell splash screen. Sometimes I could get it into the BIOS mode and occasionally would boot after that. I spent hours trying to get it to boot.
But I happened to look a the usb ports on the right hand side, one had the black plastic inner insulation snapped off and the left most pin was shorting to the case. Bent this back and boots ok now.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
My Dell Latitude D620 would not star so I pressed the Function key at the same time with the power key and the battery light is blinking off and on with the lightning bolt ⚡️ going through it. That means that the battery was dead and it's charging? I checked it and it stopped charging so I guessed I am going to have to get a used battery online.
さんによる
コメントを追加
This laptop is several years old. If anything other then the hard drive, memory, WiFi/WWAN card has failed, I would recommend replacing the entire laptop. This mainly has to do with 3 factors, outside of how old the laptop is:
  • Dell no longer makes new parts. The majority of parts that remain are used unless you find a NOS part for sale.
  • Many parts cost nearly as much as a new laptop.
  • Some parts are grossly overpriced today.
The first thing I'd suggest checking is the memory. The first thing you will want to try is reseating it. If this doesn't work and you have multiple modules, test both modules individually to find the defective module. If you find both memory modules are bad, you will need to pick up a new set of memory for the laptop to rule this out entirely. The guide to access the memory can be found here.
If this doesn't fix it, check out the hard drive. Try booting the laptop without the hard drive installed and see if you get any better results. If your laptop boots without a hard drive installed, you will need to replace the hard drive. The guide to do this can be found here. It isn't the best quality, but it should suffice.
If this doesn't work, try removing the WiFi and WWAN cards. Remove both cards and see if the laptop boots without them and reinstall them one at a time to see which card is causing the problem. If the WWAN card is at fault, the cards Dell used when this laptop was released are obsolete and are not worth sourcing today. Remove the card, tape the antennas to prevent shorting and fix it by removing the faulty WWAN card permanently. If the WiFi card is bad my recommendation would be to find a modern half height card you like and to purchase a half to full height bracket at the same time as your new wireless card. A word of caution is the D620/30 WiFi antennas may not reach with this adapter and a half height card, but this is easily ratified by replacing the antennas or using the antennas intended for the WWAN card. There are no guides to access these cards, but these cards are under the keyboard.
If you find none of these fixes work and your laptop is still dead (or it's another fault, like the display, inverter or video cable), I would recommend replacing the entire laptop. You don't need to buy a brand new laptop - an older refurb that's still usable today should suffice to replace your D620. What you buy is up to you, but I would recommend against buying another D620/30. I would consider a E6420 if you want something older that parts are still relatively affordable (and readily available). Dell still makes the battery for these laptops new, so finding a battery will be much easier then it is for your D620.
The primary reason I don't recommend getting another D620 is because Dell had to recall batteries in 2006 and 2009 due to faulty Sony batteries and this laptop was part of the recall. The site to check the battery was taken down, so there's no way to check through Dell's website anymore - you will likely need to err on the side of caution and buy a new battery to know with 100% certainty you are not using a recalled Sony battery from 2006-2009. This uncertainty leads to many sellers deciding to not include the battery and wash their hands of this 12 year old recall.
I am going to caution you here if you decide to try and source a battery and another D620 against my recommendation: While it appears Dell sells the battery again, it was also taken out of production at one point as well. It may not be possible to buy a OEM battery from Dell anymore. DO NOT BUY your battery from places like eBay, unless it is new. Many of these batteries are recalled (most sellers do not check), just about dead or have not been charged in years. You can be just about 100% certain none of these old OEM batteries will be safe to use, nor are they very likely to function.
I don't like making this kind of recommendation, but I firmly believe the D620/30 are on their last legs and it's usually better for owners to move onto newer hardware.
Dell Latitude D620 RAMの画像
ガイド
Dell Latitude D620 RAM Replacement
難易度:
中レベル
10 minutes
Dell Latitude D620 Hard Driveの画像
ガイド
Dell Latitude D620 Hard Drive Replacement
難易度:
簡単
10 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It is most likely a open solider joint on the motherboard. It is probably the memory slot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i got similar problem and got it repaired from a technician who told that it was only dust (with carbon particles and cottony material) which was cleaned up and fan could not start.... after cleaning it started normal working
durrani
Update
one more thing press FN+POWER button simultanously and see what happens... note of numlock, capslock, and scroll loack keys which one is steady green and which one flshing,,, report answer
durrani
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have this problem and the numlock button is flashing
さんによる
I am also having same issue with d630, when pressed fn+power button. Three
Locks light brighten up and then nothing happened.
さんによる
コメントを追加
Fixed mine, did all above to no avail, it was reseating the video cable which can be found beneath the keybord, and it immediately booted. Fault description was: No beep, no bios boot, no fan, no HD spin, All lights blinking fast and then off. Reseated and swapped memory, reseated HD, CPU, keyboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I took the lvcd cable loose and it booted, This tell me something is wrong with the lcd or the lcd inverter. I have it hooked up to an external monitor and it comes up fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have dell d620 problem is when I start my laptop I have to press n keep then my laptop start then desktop come properly after that if I press any key automatic gets off plz give the solution
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Plz solve my problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
my dell latitude D620 screen goes blank and stays blank when it has to boot from the internal hhd or usb or even cd, i can not even run diagnostic test. all my laptop can do now is go to Bios settings. it turns and stays blank when not at bois. plz help me...very urgent.
さんによる
コメントを追加
回答を追加する
Nikos K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 76
今までの合計 68,852
