メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
BLOD. Washer fix didn't work. Reflow maybe?
TLDR Should I try to re-flow with a heat gun?
I bought this PS4 broken for 20$. When I got home I tried turning it on just in case, and after it still failed, I opened it up and took a look at the APU bracket. The shop the guy took it to tried the washer fix, but with coins wedged between the pieces of metal. Still I took the coins out and tried the washer fix, I even got up to the high pitch noise and untightened the screws until it stopped but that didn't work either. I ordered a power supply and hopefully it'll arrive in two weeks. In the meanwhile, should I attempt a re-flow? And if so, anything I should know? Is there anything else I could try?
Thanks a lot in advance, Euler.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
20 dollars!!!! steal!! I Wish you luck. I think reflow would be better, i have seen it on the 360 and the PS3. Wish you luck,
Rishi
さんによる
Yep, thought it was a steal as soon as I saw the listing , figured even if I couldn't fix it all of the components inside would pretty much pay for the investment and maybe even a bit of profit :) .
さんによる
コメントを追加
2件の回答
ベストアンサー
A reflow won't fix it if the washer fix won't (at least it's very, very, very unlikely). You can't replace just the chip as new ones are not available. A power supply isn't going to fix it...power supply's don't cause the BLOD.
Basically your only hope is a reball but that's not a for sure thing either. That's your best bet at this point. Anyone who has done a number of these knows that many times some of the solder pads on the APU get corroded and cause the bad connection. When the chip is removed and the pads cleaned it can then be remounted to the motherboard. This fixes a lot of them but it's not guaranteed.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, I also talked to Steve on your site's chat, your PS4 BLOD tutorials were great and it is really nice that you are actually communicating with the community like this. Unfortunately I live outside of the states, and I don't think anybody here can re-ball properly. Guess I'll just have to wait for the PSU and try it anyway, and then maybe just sell the parts and break even.
さんによる
Glad you could connect with us! Sorry we couldn't help you more.
さんによる
コメントを追加
A reflow will likely bring the unit back to life for about 30 days, but the damage is in the graphics chip not just the balls underneath. Because of this, the only complete fix would be to replace the chip.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I heard that you cannot replace the chip because every chip is paired to some components on the motherboard meaning you have to buy them as a set, which no one is selling. Are you saying the chip is defective because the washer fix didn't work? is there anyway to definitively find out if it is defective?
さんによる
reflow it, and if it fails shortly after then its dead, reflow cant really hurt in your situation since its already dead.
さんによる
A reflow won't fix it. The solder pads under the APU are probably oxidized and reflowing won't fix that. It needs to be a reball if there's any chance of it working.
さんによる
コメントを追加
回答を追加する
Euler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 35
今までの合計 5,744
