メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentが製造する家庭用ゲームコンソール。PS4としても知られています。2013年2月20日に初発表され、2013年11月15日に発売されました。
Why does my PS4 overheat & turn off after opening any game?
My PS4 is turning off immediately after I open up any game, disc-based or not. The PS4 first gives an on-screen warning that the PS4 is overheating, shortly followed by the light bar on the PS4 flashing a red color, 3 beeps, then a black screen. It does not, however, immediately turn off when I am on the main screen, only when I open up a game. Does anyone have any idea why this is happening? (Additional information: it's the optical drive/HDD area which is overheating, and every time I turn the PS4 back on, it searches the HDD in the same fashion as though I installed a new one, and comes up with the error message that the PS4 what not shut down properly.)
Thanks in advance!
EDIT (2020.04.22): First off, wow I did not realize people even looked at this thread. Second, I want everyone to know I ended up sending my console to Sony, who kindly repaired it even after the warranty had expired (IIRC I only paid for shipping, it’s been so long IDEK). Thank you to Tronics as well as the many people who I have neglected these past (wow) 4 years for your wonderful tips, and best of luck to those who may have this problem in future. Stay savvy.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 22
22 件のコメント
The PS4 Pro was just discharged a couple of weeks prior and a few issues have as of now been accounted for, particularly the clamor its fan is making. Despite the fact that a similar issue
http://www.todaysblog.net/2016/11/playst...
さんによる
I'm having the same problem and I just bought my Ps4 about 2 weeks ago from GameStop. It seems to overheat without any warnings and just turns off and won't turn back on until it cools down..
さんによる
My ps4 is a first gen 1000 but it doesn't flash red it just beeps then turns off when i open any games
さんによる
Had my PS4 since release date and It never has overheated once
さんによる
just do some new cool pasta in the proccesor :P
さんによる
17件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
There are several things to check...first of all check to make sure that there is air being blown out of the PS4. If you don't feel any air being blown out then you may have a bad fan. This problem is getting more common as PS4's age. This is by far the most common cause of the type of problem you are having.
There are several other things that could be causing it as well. It's possible (especially if your console is getting older) that you need to replace the thermal paste and give the heat sink a good cleaning. This is a fairly common cause of PS4's overheating as well.
Lastly, I've seen some PS4's that actually overheat because of faulty solder joints between the APU and motherboard.
I hope this helps and just let me know if you have any further questions.
このアンサーは役に立ちましたか?
スコア 18
23 件のコメント:
Is there any way that I can clean out or replace my fan without voiding my warranty?
さんによる
Unfortunately no, but if it's still under warranty I'd be taking it back today.
さんによる
thanks for the info @tronicsfix , I'll be redeeming the warranty as soon as possible :)
さんによる
No problem! Hopefully you get a better one this time!
さんによる
Playstation support never sent me a box to ship my ps4 in, so now my warranty is officially over, which means that i'll have to either find someone who CAN fix it, or fix it myself, but i'm not very confident (as this would be my first repair).
さんによる
18件以上のコメントを表示
コメントを追加
Someone help me my ps4 is fully cold to the touch but when I start up a game it says it’s too hot and overheating and shuts down I NEED HELP BADLY I stream a lot and I have 20k put into streams and my computer and ps4 and it collapses please help
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
And I’m in Sunday pro league tournaments for RB6
さんによる
Mines did the same thing yesterday I made a appointment to take it to geek squad today it flashes red and beeps 3× I had mines since 2013 and this is the first time it happen note*when I turn on when it's cold ps4 is quite and I hear a sound like the fan wants to turn over
さんによる
Did geek squad help?
さんによる
コメントを追加
Because the fan has stopped working or its so full of dust and dirt the heatsink fins are not getting air across them ....check your wall voltage make sure its not low .....junk heat sync compound is common as well
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
score of 1 and you rate the same answer a day later a 5 ....bet i dont give any more help on this site ..my answer was short and direct as well as correct
さんによる
I noticed that
さんによる
What would I have to clean because I don’t know where the fan is?
さんによる
コメントを追加
I have the problem where seconds after loading into any games it shows the overheating screen and turns off what should I do?
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Same. I can literally do everything else on my ps4 but soon as a game starts up it overheats and shuts off immediately.
さんによる
コメントを追加
fan is not working ...leave it off in till repaired .....common problem easy fix your self for 5 bucks , youtube how to do it ...then put a ssd and new diamond heat sync compound and it will out preform any stock ps4 made
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Carl can you help me. I have this issue. What's the compound for?
さんによる
It's for the cpu. Everytime u open up the ps4 and remove the board u need to replace the thermal paste, hence the compound. Ensure it's a good thermal paste. Arctic mx4 or mx5 is highly recommended.
さんによる
コメントを追加
My ps4 overheats when I turn on any game downloaded or disk but when I am on YouTube Netflix or the home screen it’s fine I’m trying to factory reset now I don’t understand why it only does it when a game is being played
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
You need to clean the dust out of it (assuming your fans work and get super loud when it overheats?). I took mine to my local garage and used their air hose to blow out TONS of dust in there... got it home and tuned on God of War and it was quite as a lamb (couldn't believe the change). So yeah just got to blow her out from time to time ;)
さんによる
I accidentally stepped on my PlayStation now it won’t load anyone know how to fix it?
さんによる
My just gave out an hard poof and it just powerd down
さんによる
コメントを追加
My PlayStation did the same on the change the HDMI cable and hdmi output
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My PlayStation 4 do the same they saying You must change the HDMI output from the PlayStation 4 and you must clean the dust from the machine because of the stop the van inside is not working and making loud noise
さんによる
コメントを追加
Every time i turn my ps4 on it over heats really fast I cleand the dust out of if and everything pls help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The Connection at the end of the fan wire Is prone to damage if not removed by a skilled person every system that I have worked on it was either disconnected or broken which was causing it to shut down To prevent overheating If it is notconnected it will not even power on Consistently you will get a blue light when you press the power button it will never change to The white light That indicates it is functioning properly blow dust and crap out after fan fix
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have cleans the inside and the outside of my PS4 and also invested in a cooling fan yet it keeps overheating what should I do
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Where do you keep your console? In my case, it was choked because I kept it in a TV stand cupboard. That’s the first thing I’d recommend, moving your console if it isn’t already in open air. Beyond that, I’m more familiar with PCs than proprietary console configs, so your guess is as good as mine.
さんによる
if youre already opening it up to clean, check that nothing has melted. may not even be able to notice. i once had one that overheated every time i plugged any second usb into the console (controller and mic) it was a slim and i sold it off for the going price, i was just honest with the dude. ur best bet if none of this helps is to bite the bullet and send it into sony.
さんによる
I hear that 3 beep on ps4 cause is not an a well ventilated area
さんによる
コメントを追加
Thanks My PlayStation my ps4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My ps4 overheats if I play dead by daylight, but not games like minecraft, fortnite or siege I dont understand it, I have cleaned it moved it from other objects made my room an ice box and it STILL overheats
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My ps4 is telling me that it's too hot as soon as the blue title screen appears. It has never done this before. I've had it at least 6 years. What should I do? I can't even watch Netflix or YouTube on it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Reall さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 45
過去 30 日: 185
今までの合計 398,644
