How to set injector pump timing
How do I set the timing on a injector pump installation?
As mentioned, change your user name first.
You don't set timing of your injectors. The computer is responsible for energizing the injectors. Typically there is a crankshaft position sensor and other inputs that provide input to the computer to determine when and how long to energize. Basically, you install the injectors and start the car; the computer does the rest.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 307
Besides changing your user name you also want to be a bit more descriptive. What 6.9 L engine? What vehicle? Why?
oldturkey03 さんによる
Late 90's Chevy Pick up, Suburban, Hummer?
LS Computer Systems さんによる
