How much would it be to diagnose a problem?
I got my hdmi port repaired but now it's blinking red and I don't know what's wrong with it.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You don't need it diagnosed...I can tell you what's wrong just based on the info you gave: whoever fixed it, didn't fix it correctly. Most likely they did not solder the 19 small pins on correctly. If they are a good business they will fix it again for free (assuming that the port hasn't been abused or anything). If they refuse then you'll need to have it fixed again.
このアンサーは役に立ちましたか?
Before blaming the person that tried to fix it, try a new hdmi cable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 64
