メインコンテンツにスキップ
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60回答 すべてを表示
Laptop won't turn on.
Plug the charger in and no charging lights come on. Power button makes a clicking sound when pressed. New after market charger. Battery reads 3.2 when tested on ohms meter. What is the problem? Also, looked at ram and it say 2GB. I thought this model was minimum of 4GB.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The fact you don't even get a charging light could mean that the charge port or power board is faulty.
It's tricky to diagnose without a good root around but my next guess would be the CMOS battery could be dead.
If replacing that didn't sort it I'd look to the RAM. Faulty RAM would stop the BIOS/CMOS from even starting, but then again I think you'd still get a power light.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Davis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 502
