What soldering tip shall I use for soldering the display?
I am trying to solder, what I believe to be the power source ribbon to the logic board. Can someone recommend me a soldering iron, and tip to use with iPhones?
Thanks
Use one of temperature controlled soldering iron with a digital display such as the Weller WE1010 soldering iron. That way you will be able to precisely control the temperature of the iron to within 9 degrees Fahrenheit.
There is a guide for choosing the best soldering iron:
http://soldering-irons.com/best-solderin...
Regards
このアンサーは役に立ちましたか?
Great link for advice
good answer +
did you break the old ribbon cable? because you shouldnt need to solder anything
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,518
