メインコンテンツにスキップ
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
4098回答 すべてを表示
iPhone 5S bricked after battery replacement
I went to replace a battery on an iPhone 5S, it obviously should have been a simple replacement but i went to reassemble the phone and it was dead. I have replaced every component to find the issue, the lock button flex, charging cables, screen, different batteries... no avail. I believe it is a logic board issue but I have no idea which part or how to fix it.
Is there something that a faulty battery or battery replacement could do to brick a 5S?
Any help would be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
Try the original battery again.
このアンサーは役に立ちましたか?
スコア 0
コメント:
I tried the original battery and a battery from another 5S - neither did anything. The phone remained non-responsive to anything - not recognised when plugged into my Macbook either
さんによる
Look closely at the logic board for missing components, had an iPhone 5c a while ago that was missing a tiny resistor and wouldn't show anything on the screen.
さんによる
If I look carefully enough, should it be fairly obvious if there is a part missing? Will I need to take off some of those component shields?
さんによる
i just had the same problem. replaced battery and device bricked. went back to original and can't keep it work again. when i try to turn it on, screen is black, but iTunes recognize it (it asking to unlock the device password, but i can't do it)
さんによる
Yeah, see unfortunately the iPhone isn't even recognised when plugged in
さんによる
1以上のコメントを表示
コメントを追加
Check the LCD connections. I usually don't remove the screen when doing a replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It's not unfathomable that a third party battery could damage a motherboard.
Why not try removing the board and placing in another 5s that you know works? It's the quickest way to eliminate other possibilities? Good luck
このアンサーは役に立ちましたか?
スコア 0
コメント:
I've done this, tried a new iPhone 5S housing which had components in. I think it must be a logic board issue, are there places that fix things like this?
さんによる
No good news unfortunately... There are people / companies out there that will repair iPhone motherboards, but as you can't pinpoint the fault it could be an expensive experiment. Personally I'd probably sell the phone for spares and look at getting another one :(
さんによる
コメントを追加
Hi, I had a similar problem with an A1533 where the battery completely died. Think it was caused by overheating as the front panel w/LCD was detached from its frame!! I jump started the battery using hooked pins and an external low current charger from an old defunct phone pack but had to take it out of the frame to get to them however this worked fine and phone starts/runs with battery at about 20%
The 5S and 5C batteries are very similar but not identical, even if it fits in the available space its connector is wrong.
You might have damaged it in the process so worth checking under a magnifier for bent or missing pins, or a cracked connector housing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Max Shepley さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 860
