メインコンテンツにスキップ
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30回答 すべてを表示
How to repair a USB port that won't accept a USB device?
I tried to plug in a USB cacble to my Toshiba Laptop and it would not go into the purt completely. The connection was not complete as the device I was trying to plug into the Laptop USB port would not work. I am not sure if the problem is with the Laptop or the USB connector on the device I was trying to plug in. How can I identify the correct point of failure? Would it be on the computer USB port or the usb device I am trying to plug in.
Once this is determined, how can I repair the USB connection, or does this require parts replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
droyhull sounds like a mechanical issue with the port since you cannot properly insert a USB cable/device. In that case you will have to solder a replacement USB port unto the motherboard.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
droyhull さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 166
