FireTV Stick seems broken when I turn it on for first time
Amazon logo pops up for a second when device is reset, but then it disappears. No luck getting fireTV Stick to work. Any ideas?
Turns out this link will take you to where you can contact someone at Amazon for help.
https://www.amazon.com/gp/css/contact-us...
If you don't want to contact Amazon for help, consider whether you've properly registered and setup the device prior to trying to use it.
このアンサーは役に立ちましたか?
Make sure about that you have properly registered and setup the Fire TV Stick device. If you are unable to find any solutions, then you can looking here for troubleshooting fire tv and perform or follow step by step procedure to continue your device.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 483
