メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
196の回答 すべてを表示
iPad doesn't charge after battery drain
I have this iPad that charges and works fine. But as soon as the battery percentage goes to 0. It won't charge anymore. There must be a motherboard problem. What component should I replace?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
With these details we can't exactly help or at least describe but if you go to Apple they replace the charger and inspect the product its self. I was thinking that if it has some sort of overlapping ridge on the charger that is it problem and you must go to Apple for that or else your iPad will become bro land you won't be able to access it. I'm sorry that this is probably not the answer you were hoping for but this is the closest I can get with these details.
この回答は役に立ちましたか?
スコア 0
コメント:
This would probably some what help.
さんによる
Hi Albert, first time i got the iPad it was dead. the customer told me they had problem with the battery before. So i replaced the battery and everything looked fine. Now a few weeks later the customer is back and the iPad is dead again. So i replaced the battery again and the device booted up normal. After some experimenting I came to the conclusion that the battery won't charge anymore as soon as it gets below 0 %.... so my question is what component on the motherboard should i replace? i do have soldering skills :-) ...
さんによる
コメントを追加
回答を追加する
ifixshop さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 125
