Released February 2016, the Vivo 5 features a full metal body—a first for a BLU phone.
37の回答 すべて表示
Black screen on Blu Vivo 5
Just recently purchased a new Vivo 5. had it in my pocket and it fell to the floor roughly 2 feet. Screen is now black but it turns on. Very disappointed as i had only been running it for a few hours. Not a very robust phone compared to my BB Priv. Will it need to be fixed or will i be able to recover it enough to make it usable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
I as well have a Blu Vivo 5. I have had mine for 7 months already & I have dropped it a couple of times. Recently on Christmas Eve I dropped it and the screen had a bluish/ blackish stain on the top. And on the right corner it had a small green stain. A while later, my brother accidentally spilled water on it. Now after a few days, ONLY WHEN I TURN IT ON, there is a huge black stain that doesn't allow me to see my apps. There is just this 2 inch space were I can barley see some of my apps. Please help!!! What is it? How can I fix it?
による
The phone works perfectly. The screen was never damaged; its not cracked. Only the inside when i turn it on
による
I cannot figure this out! I have the same exact problem, I had dropped it multiple times before, but nothing serious. One day I dropped it barely 3 ft from the ground and now the screen is both black and has these small internal cracks on the screen, and ive only had the phone for A MONTH AND A HALF. Normally Blu has great phone quality but I have had many incidents with Blu phones and sadly have to turn over to iPhone if Blu doesn't make the phones sturdier.
による
i have the same problem but don't know how to fix it.
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
4回答
I'm currently having the same problem it may be an issue with the drivers in the screen display my recommendation would be to just replace the unit
この回答は役に立ちましたか?
スコア 0
コメントを追加
Does anyone find out how to fixed the same problem as you wrote above ??? Please help :(
この回答は役に立ちましたか?
スコア 0
コメントを追加
The only solution to this issue is a full replacement of the screen. The colors, lines, and black blotches are natural when any digital screen is damaged. Some are more durable and don't have this and others get this by just by pushing on the screen to hard. The simple answer is you have to use a heat gun to heat the adhesive on the phone and use a suction cup plus a thin prying tool to remove the screen. Google or find on youtube on how to replace BLU vivo 5 screens as it will go more in depth and following my simple instructions will damage your phone. Considering how cheap this phone is, I feel it is not worth the cost of replacing just the screen so I would advise to just buy a new and different brand phone.
この回答は役に立ちましたか?
スコア 0
コメントを追加
How to repair grounded phone Vivo v5s?
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Williams さん、ありがとうございました!
統計データを表示:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 74
今までの合計 3,244
