メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
679の回答 すべてを表示
Broken some pins on the logic board
hello guys
I swapped the GPU and added an SSD but i accidently damaged some contacts on the logic board these are forconnecting the display.
here some pictures:
http://imgur.com/a/d2gun
How should I proceed
thank you
Update (06/06/2016)
Thanks for the answers I got some knowledge in soldering I should be able to do the job if the bending doesnt help
Can anybody hit me up with a link where I can buy this part?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If they're just bent (I can't tell for sure because the picture is a bit blurry) I would recommend using something like a small flathead screwdriver and gently attempting to straighten them. If you get it close enough, the cable should mate to the connector without much issue. Those look like they're just contacts and not pins so they don't need to be perfectly straight. According to what I've read those pins are for display power so they're pretty important.
この回答は役に立ちましたか?
スコア 3
コメントを追加
You'll need to find someone to replace the connector for you. As they say plumbers can't do brain surgery, don't feel bad I'm a plumber too! ;-}
The only other option is to see if you can get a replacement logic board but that will be costly too.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
pulac77 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 187
