メインコンテンツにスキップ
Electronic doll produced by Wicked Cool Toys in 2017. The bear is able to move its LED eyes and mouth to ‘read’ stories to children.
25回答 すべてを表示
The tape doesn't play. It starts and stops!
I have a Teddy Ruxpin from 1983. It has worked all these years but now, the tape won't turn. It starts, then stops completely. Is there a repair shop, to fix it? It's in excellent condition.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
選択されたソリューション
This video address how to fix that issue: https://www.youtube.com/watch?v=WGXhaNY7...
This one is one the drive belt: https://www.youtube.com/watch?v=vgT5l6R_...
This one is one the playback spring: https://www.youtube.com/watch?v=MgQ78PX4...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
first of all he is made in 1985 by worlds of wonder. which is the version that I'm guessing you have. the problem is either a warped drive belt, a loose battery or connection problem, or most commonly, a dented pinch roller. one of them that I have is a first gen with a metal player. and that one used to have a dented pinch roller. which was causing that start and stop thing. exept mine was doing it faster, causing a blipping sound. so all you have to do is to buy another replacement pinch roller and go from there. good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Patricia Hufenbecher さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 85
今までの合計 11,385
