It won't charge after changing LCD
Hello,
I repaired a Huawei P8 Lite today and while I installed the new LCD I held the power button to check functionality. The power status LED on top left front turned on Red and then faded. It was 2+ weeks without a charger so I thought it might be empty. I finished the repair and put everything back together and on charge.
But after 5 hours the device still doesn´t react when pushing the power button.
I disassembled everything carefully but couldn´t find any damages done to the phone.
And wouldn´t the battery have to get a little warm while charging? The phone remains cold. I will wait till tomorrow and hope for a recharged phone, but any clues in advance?
Greetings,
Michael
I have the same problem, after changing screen with frame it does not start from power button, when charger is plugged in it blinks red 3 times, then once longer and the screen flashes for a moment.
When i hold vol down button and then hold power button the screen flashes for a moment repeatedly.
Mergal さんによる
If the red dot flashes when connecting the phone to the charger, then you have a problem on the battery or the MB power connector is damaged. Test all MB battery connector pinouts against ground pad. The two pin in the middle don't gives you continuity, but check resistance that should be about 3.7 ohms. If the connector it's ok, then change the battery.
Ruben さんによる
Did you find an answer to your question? The same appened to me.
Thanks!
Enrico Camillo さんによる
No answer. I am still looking for it.
I am looking now for a hint, how to recover from the storage of a broken phone...
M K さんによる
i just remove back cover and phone id totally dead
Artan Sermaxhaj さんによる
2件以上のコメントを表示
