メインコンテンツにスキップ
2012年11月2日に発売されたiPadの第四世代です。Wi-Fi, CDMAもしくはGSM モデルがあり、16、32、64GBの容量オプションがあります。
408回答 すべてを表示
iPad Lock Button doesn't work
I have sort of an odd problem that I was hoping someone in the community could give me a hand with. My iPad 4th gen wifi has some odd issues with the lock button. Not only does it not work (even after replacing the lock button/volume ribbon) when the iPad was in use the assistive touch menu would not even lock the device. I was wondering if that could indicate the problem being more logic-based or if it was perhaps a fault in the board that connects the headphone jack, cameras, and lock/volume buttons to the logic board?
Any help would be great.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Id try another lock ribbon cable and see if you cant find a replacement board that the lock ribbon cable plugs into. I think they are separate. I cant remember off the top of my head, if they are or not. I had the exact same issue and it was the lock ribbon cable needed replacing.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for the help, I'll give it a shot.
さんによる
コメントを追加
回答を追加する
Preston Stone さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 145
