メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Backlight works but no images on lcd after install.
So I received my "high quality" screen from ifixit and installed it super smooth as 50 times before and it worked for about a day then customer asked why 3 buttons on the screen didn't work then apparently the phone powered off and all I could get on that screen was the backlight and 2 purple lines about a fourth in on the right side. So of course I went to slap another screen on and even tried oem but all I get is a backlight. Have tried home and power and disconnect battery and plugging it up with no success. HELP!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
this problem looks like you either burn the video chip out or maybe on the connectors they may be something that is not letting the lcd cables to direct connect with board
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Seems like the backlight chip is messed up. Can you try flashing a light on the screen and seeing if you see anything on it really dim or not.
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
loganperkins42 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
