no touch function lcd
Hi Guys
i have been reparing an iphone 6 and replacing the lcd. but ran into problems with the lcd after the new ldc was mounted. all Things seem to Work fine but the touch is not responding i can´t swipe to unlock an activate the phone. i hav tried to Mount the old lcd and still the same issue. the conectors looks fine and the and are not bend. anyone with the same problem?
What is a ldc? Was the touch screen / digitizer ever working before on the old screen before you tried a new screen?
Ben さんによる
LCD typing error sorry. yes the touch screen worked before !
Carsten さんによる
Have you tried resetting it. Power button home button) or battery reset.
Dre Cannon さんによる
Yes, have tried it
Carsten さんによる
The touch is not the LCD its the digitizer on your iphone 6 its the connection at the top. When you say you mounted a new LCD did you try to separate the LCD and the digitizer. Or did you order a assembly
Dre Cannon さんによる
