メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
How to access data off iPod touch(4th) when it is completely dead
I have an Ipod Touch 4th Generation that cannot turn on whatsoever and is not sensed by my computer at all....I have already tried holding power and home buttons for 10 seconds and it is still not sensed. I have tried grounding the battery with no luck, not even a spark. The screen shows no signs of life and its basically a block of metal at this point.
I have given up on trying to fix it because I have went through 3 screens thinking it was that and still have not been able to get it to show any signs of life.
All I need to know is if there is a way to access the memory without the device being turned on or if I can remove the memory and attach it to a different device to access it.
I have many old photos on the device and I have not backed it up to anything, so any help would be greatly appreciated.
If there is a possible way of fixing it from its current condition, that would be even better, but I am just worried about the data on the device, not so much the device itself.
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Alexander,
What was the cause of the death of iPod ?
Was it liquid damaged or was not used for a long time and now doesn't wakes up at all.
Depending on answer to above question i help you with the steps to get the data out of it.
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Went dead after an attempted screen replacement. no water damage
さんによる
コメントを追加
回答を追加する
Ben Alexander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 136
