メインコンテンツにスキップ
Model A1138 / 1440x960 screen resolution
85回答 すべてを表示
Why can't I get the last two screws to go in?
The last two screws on the bottom near the hinge won't go all the way in? All the others are perfect. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Go back over the guide to see if you installed a couple of shorter screws into longer holes.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Seems likely +
さんによる
No, they are identical, the longest of the lot. They only miss by a little, like they have bottomed out. Tight, but not all the way in. I tried getting the blue Locktite off the screws to see if that would help, but no.
さんによる
Please check the guide you used and the length of each screw (they are all listed). Use a millimeter gauge if you have one. Trust me, You have used shorter screws than required somewhere during your reassembly.
さんによる
From the guide:
"Four 16 mm Phillips along the hinge.
Two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment."
All the rest are 3 or 5 mm. If I had them swapped, I would have had to put a 16mm in the 12mm hole in the battery compartment.
さんによる
What guide were you doing?
さんによる
1以上のコメントを表示
コメントを追加
The reciever
holes on the top case may be bent, blocked or stripped.
These two screws go to hold the back of the top case check the clearance and those tangs.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Top case, where the keyboard is? I won't be able to get to it until later, but I will pull that off and check. I replaced the DC & Sound Card because the DC in port pulled part of the power cord off, and was unusable, now the battery won"t charge. Getting power at some of the pins in the battery bay,
さんによる
コメントを追加
回答を追加する
michaellarson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 824
