メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
317の回答 すべてを表示
Can SIM tray holding module be replaced in my Galaxy S7 edge?
I dropped my GS7 edge form a knee height and made a tiny dent right in the middle of sim tray, now it is stuck and cannot be ejected, snet phone to Samsung repairs and they want to charge me $264 for front LCD replacement which I think it's outrageous. So my question is if ifixit can replace just the SIM tray inside module? thnks
PS So mad to pay for some expensive gadget and Samsung uses flimsy material for sim tray...go figure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
This could probably happen to a iPhone too.. I'm guessing this part is where the frame is bent as that is somewhat part of the sim tray holder too.
さんによる
コメントを追加
4件の回答
Can you upload a picture so we can see the damage and the photo from the Samsung report if they gave you one.
この回答は役に立ちましたか?
スコア 0
コメント:
I'm still waiting to get my phone back, it's been more than a week, and since SIM IS IN the phone haven't been able to send receive calls with that number, I will post pic as soon as I get it back but report I will only send privately.
さんによる
With the report they sometimes take a photo and have it with the report. We wont need to see the full report just photo they attached to it and hopefully see any internal damage to the frame.
さんによる
コメントを追加
i have same problem... frame is blocking simtray from exiting can it be repaired ???
この回答は役に立ちましたか?
スコア 0
コメントを追加
Yes you can do it by yourself by reading the ifixit' s menu. But it's really not recommend because your phone will lose the ability of waterproof and there's a extremely high chance that you will damage your phone. Go ahead if you don't mind taking a risk.
******I'm not responsible if you damage your phone. Do it on your own risk******
Follow these steps:
1. Take a suction cup, heat gun, heat glue, tweezers, soldering iron
2. Turn on the heat gun and set the temperature at around 80-85C, heat the whole phone. Remember not to heat the battery to much!
3. Take a suction cup, suck it onto the phone. Try to pull it out, if it still sticks, turn the heat gun to around 90C. Heat the edges for a short while. (Don't melt the suction cup!!)
4. take the tweezer , and peel away those adhesive tape away asap or not you will have a hard time with them.
5.When you remove them all, you will see the motherboard and the battery, unplug the battery first.
6.Then remove the motherboard. And the thermal paste
7. you should see the bent sim tray, heat the soldering iron up, after heating, try to remove the sim card first because you have a high chance of damaging the sim card. Then, put the soldering iron onto the bent sim tray.
8.Take the tweezers, try to bend the bent area. Then pull the sim tray out.
9.Put the sim tray aside. Unbend it with your own way.
10. Now start resembling the phone. YOU MUST PUT THE BATTERY CABLE BACK!! Take some good thermal paste like Nt-h1. Don't put too much! After putting those sticky adhesive tape back. Use hot glue and put it on the edge of the phone. Put the phone's back cover back to the phone.
11. You should be okay now. Now boot your phone!
12. That's all! good luck ^_^
Warning: your phone may still be waterproof but not as good as before
この回答は役に立ちましたか?
スコア 0
コメントを追加
My sim try got broken when I attempted to force it out
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
audgtize さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,596
