battery compartment won't close & won't click when battery is put in
I'm not sure what the problem is but I put battery in pushing in orange battery latch and it does not latch
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The battery pack should click into place without requiring excessive force. If it does not, be careful not to force anything as this will make things worse!
Check the following:
このアンサーは役に立ちましたか?
byte me (12 characters plus)
There is a sequence THAT MUST BE FOLLOWED TO CLOSE THE BACK COVER SECURELY. STUDY THE BATTERY FACING SIDE OF THE BACK COVER CAREFULLY - PONDER FOR A MINUTE AND THE PROPER SEQUENCE WILL BE REVEALED. iTS CLOSE THE SIDES FIRST AND THEN THE TOP AND BOTTOM NEXT.
過去 24時間: 2
過去 7 日: 13
過去 30 日: 59
今までの合計 10,066
