メインコンテンツにスキップ
ニコンの一眼レフカメラとポイントアンドシュートカメラ用の修理ガイド
1495回答 すべてを表示
Why won't my Nikon Coolpix L830 camera turn on?
I have tried new batteries, heavy duty ones in fact yet my camera still won't turn on. One day when I was taking photos my camera died out of the blue and the lens hadn't reversed back in to its place & ever since my Nikon L830 hasnt turned on... Do I seek professional help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
if you can catch the attention of @flyingdutchman he can probably help you out as he is quit knowledgeable with all things camera This is a link to his page
https://www.ifixit.com/User/Contribution...
さんによる
コメントを追加
2件の回答
ベストアンサー
Here's one thing you might try:
Remove the batteries and the memory card. Wait for half an hour or so, and put the batteries back in but not the card. See if the camera will turn on . If it does, switch it off and put the card back in. The camera should now continue to operate normally.
A few points:
  • If you've left the batteries in the camera, they may have discharged in the meantime even if the camera was switched off. Use fresh batteries.
  • Digital cameras, particularly chunky bridge cameras like the L830, are really fussy about batteries. Only premium quality batteries will work well. Better yet, get a set of premium quality NiMH batteries like the Sanyo/Panasonic Eneloop brand. They last longer on each charge than a set of good alkaline disposable batteries and are much more economical in the long run.
  • If the camera refuses to operate normally after you put the card back in, the card is probably bad. Replace it, and don't forget to format the new card before you start using it (the camera will complain if you don't).
  • If the above procedure doesn't solve the problem, check for corrosion or dirt in the battery compartment. A pencil eraser can be used to clean dirty contacts. If there's visible corrosion (rust or greenish crud) it might be better to have the battery compartment cleaned by a professional as there might be collateral damage. Make sure to remove any debris before you put the batteries back in.
  • Finally, if you're not having any luck after all of the above, start looking for a competent repair shop.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Sounds like the power supply inside has failed.
May need to be repaired.
If it is under guarantee take it back to the retailer. If not just seek a local camera repair centre
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
Hey Davis, what is this obsession you have with telling people to take things in to be repaired? This answer is useless!
さんによる
My Bad.. New to the site and trying to help. I will take your feedback into consideration tho Mayer. Cheers
さんによる
Thank you Davis for you advise.
さんによる
コメントを追加
回答を追加する
Samantha Turner さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 109
今までの合計 17,357
