メインコンテンツにスキップ
2014年9月19日に発売されたこの4.7インチ画面のiPhoneは、iPhone 6 Plusの小型バージョンモデルです。モデル番号はA1549、A1586、A1589で識別できます。
5202回答 すべてを表示
Died after fall down
I fell my phone in the floor then it become very hot then switch off died
I try to switch it on , recharge it
No way
What and where the damage happend?
Can the battery damage from one fall?
For your advice
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Where does it get very hot? Is it at the top right of the phone? You can check this from touching the back metal housing of the phone. Sounds like a power management chip has gone bad.
さんによる
Hallo
I did change P M and the battery but still not working
Please note my Iphone bought from Dubai and they told me that parts for Europ is diffrent .. Is that correct??
But the P B i did change also for middle east // I have spare Iphone///
For your advice
さんによる
Hallo
I just confirmed with my brother, the heat started 1 cm under the back camera then it became tooooo much hot then it hearted him realy cus of high heat
さんによる
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east only ??
さんによる
コメントを追加
2件の回答
Going on with what "Ben" said it is most likely the power controller chip and it is very hard to replace and it may have damaged other items in the phone as well so... Time for a new one....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you try to restart it by holding the home and power button for about 10 secs?
このアンサーは役に立ちましたか?
スコア -1
コメント:
How to restart it if it not working at all, there is no power
さんによる
Pretty sure the only way to fix is getting some IC or component chips replaced. Its hard to find which component chip is at fault on the logic bard upper half.
It's 50/50 chance of fixing so it might not even be fixable if the damage is too bad.
さんによる
My phone was bought it from middle east and now iam in Euorpe, If i fix euorpen part in middle east Iphone , it work or no as it must be middle east too???
さんによる
コメントを追加
回答を追加する
Imadeddin Sukkarieh さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 628
