メインコンテンツにスキップ
Original screen worked but was broken, new screen backlight won't work
I have an HP Stream that had a broken screen but when I swapped the screen out for a working one, the backlight doesn't work. I don't think these laptops have a replaceable inverter so how do I get the backlight to work? I have tried the new screen on a two separate HP Stream that had lit but broken screens and the same thing happened to both so I don't think its the motherboard. I have also tried resetting the HP to factory settings to no avail. Anyone have any other ideas to try? Has anyone else had this same problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Hi, Does it have the same part number as the original one that you are replacing? I assume that it is the correct screen for the laptop?
You say that it is a working one but then you say it is a new screen. If it is a new screen have you actually seen it working?
Bit of work but did you try one of the other lit but broken screens in the first Stream, (if they are also the correct screen for the laptop)? If the backlight works (obviously not the screen) it proves the laptop OK and that your new screen might be the problem.
さんによる
Yes I did. I even put the original screen (the broken but lit one) that came with the Stream back in just to see if it would work and the backlight still didn't light.
さんによる
there is a fuse on the mother board the goes out easily. there is a video on youtube that shows how to fix it.
https://www.youtube.com/watch?reload=9&v...
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
If you hadn't said that you had tried the 'new' screen in a different laptop I would have suggested that you check the connections of the 'lid switch' in your laptop. This switch turns off the power for the backlighting when the lid is closed.
Here is a link to the service manual for your laptop. Scroll to p.4 to see the lid switch location.
http://h10032.www1.hp.com/ctg/Manual/c04...
Does the original screen still work in the other laptop? (Backlight only of course).
You might have a 'double header', i.e. 2 faults.
1. New screen backlight circuit faulty, therefore doesn't work anywhere.
2. New fault of backlight circuit not working in original laptop. (see above re lid switch)
This scenario would be one answer to the problems you are having.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I will try that, thank you so much for your help!
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jason Kratochwill さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 2,518
