メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
Anyone here do a screen replacement before? Have a question
Im looking into replacing a friends screen. On amazon im seeing screens with some cables on the top and i see some prongs.
Are those just (i dont know how to describe it) pull out and push in ends into the screen? Or are the soldered on? If anything else, PLEASE let me know! :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Done it before and I will never recommend doing this. It was a pain to install as the first time I did this, I burnt out the charging port because I didn't cover the soldering joints for the charging dock connector so that it doesn't touch the metal plate that sits on top of the logic board and under the front display.
Also broke the wifi antenna cable and had to order a new battery. Another time I broke the LCD ribbon cable which is then a waste a money. I say do not repair it and buy a phone to replace the ipod.
The ipod touch 5th generation is hard to repair and is not worth repairing IMO.
I've only repaired this successfully two times out of 4.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I heard a pop when repiring mine. and now the screen is just black. what do you think I broke.? it still makes noise when I plug it in.
さんによる
コメントを追加
回答を追加する
Jay Kay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
