Clutch /brake pedal adjustment LT2000
Need info on my LT2000 Craftsman riding mower. On adjusting the brake/clutch pedal. The tractor will not stop any longer when you push the pedal all the way. It also is having trouble on hills like the belt that drives it is slipping and needs to also be adjusted, or does one adjustment take care of both, Any help greatly appreciated.
6 件のコメント
I think the clutch and brake are both adjusted at the same point, at the rear brake assembly. There are some belt adjustments, but I'm not sure they apply for this.
Jim Mike さんによる
when i let out the clutch i get a grinding sound, i do have brakes
victoriawinters14 さんによる
I have to have my brake halfway in then push the lever forward for the mower to go forward or reverse its gotta be something broken inside the transmission the lever does nothing when the brake is off but the mower will move when you push the brake pedal halfway down on the craftsmen 917.271080 model. I think my problem is inside the transmission not no simple spring on the outside
Turtle Frog さんによる
Recently I bought a Lt2000 Craftsman Briggs Stratton 17.5 42”, just change the drive belt on and now started problems with the new belt jumped it out of the guide pulley and not clutch return, so the mower keep running and to stop it I have to turn off it.
Thanks in advance,
Juan Jirau さんによる
When I push the brake clutch pedal in and then release it it makes all kinds of npines of noises what is causing this
William Johnson さんによる
1以上のコメントを表示
