dose motor have to be pulled out to install cam bearing
Dose motor have to be out to install cam bearings
5.7 & 5.3 no, but i recommend it highly.
You could remove the front grill/radiator mount and possibly the bumper depending on clearance. BUT that means, radiator, oil/transmission cooler (if you have those), grill, lights, wire harness, battery removal. You can pry the mount out without removing the quarter panels and wedge it in. Just take care in doing so or you'll have to hammer out any damage you caused to them.
Im not sure about any other engines.
このアンサーは役に立ちましたか?
How you you get to the rear cam bearing if you don’t pull the engine?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 65
@mikey00069 what exact model and year is your truck? what engine does it have?
oldturkey03 さんによる
