メインコンテンツにスキップ
Released on May 1, 2015 by LG. Can also be identified by LS770.
26回答 すべてを表示
My lg g stylo power button doesn't work
My power button doesn't work on my lg g stylo. Does anyone know how to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
9 件のコメント
Did you ever solve this? I'm having the same issue.
さんによる
I'm having the same problem
さんによる
Lol if Albert Einstein can't fix it then nobody can XD
さんによる
My power button on my stylo 4 isn't working
さんによる
My button on the back of my phone don't work
さんによる
4件以上のコメントを表示
コメントを追加
9件の回答
最も参考になった回答
This worked for me.. take off the back case then plug in your charger. With the charger in remove the battery and put it back in. Restarted my phone. The power button is still not working but I can access it by tapping the screen. Hope this helps
このアンサーは役に立ちましたか?
スコア 10
10 件のコメント:
Thank you that worked. I had the same problem and I knew there must be a way to get it turned back on.
さんによる
Thank you! This worked for me also!
さんによる
WORKED!!! You're a genius! :)
さんによる
this also worked for me
too !!
さんによる
OMG I had the same prob,I have been trying to figure this out for weeks and it worked thank uuuu
さんによる
5件以上のコメントを表示
コメントを追加
Taking off the back and taking out the battery for 15 seconds worked for me. I also noticed that the battery symbol showed it as charging, even off the charger, so that mustve been the glitch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try updating Android. That actually worked for me.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
omg this totally worked.. thank god!!!!!!
さんによる
コメントを追加
Mine does that too… just keep plugging and unplugging the charger in a bunch of times and it eventually turns on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have to actually connect the charger and then in some cases kind of press the bottom of my phone to get it to vibrate and come on and then sometimes when I take the charger out it goes blank and I can't turn it on again but it does work with a charger plugged in
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I was having the same issue earlier today. Tapped the power button repeatedly about 20 times out of frustration then held it down like usual the last time & it started working again. Must be a glitch or something. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I took the phone completely apart with a small screw driver and clean the contacts that lead to the power and volume buttons under the inside cover and put it back together and now it works fine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I could do this. Thanks!
さんによる
コメントを追加
I went to setting in the display area and and turned off the switch for the power button and then turn it back on I haven't had problems since doing it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
plug in the charger and press the volume down button holding down until it comes on if that did not work try it again still not working try different combinations with charger and volume buttons that worked for me but it took a few tries for sure. hope it works for you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tamikarose5 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 53
今までの合計 17,383
