メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
Ps4 turns on using controller only, internal Peripherals won't work.
Hi All, i'm new and i am from Italy. I'm trying to fix my old ps4, a first gen model (chassis A). So, after thermal repaste my ps4 won't start up using capacitive lid sensor (power button) but sometimes i'm able to start it up using the controller ps button. Warranty is obviously voided and I don't want to pay 150$ to replace it because I've already bought the new 1Tb ps4 model. The strange thing is that every internal pheripheal (including capacitive buttons and optical drive) doesn't work. i think it's not a power supply issue... Software Maybe? it seems like the main motherboard runs on her own without communicating with others Hardware pieces! Do you think a Motherboard Reballing Could Help? Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Either you damaged some components / cables or they are all not plugged in properly. It's also possible that the connector plugs for the ribbon cables are damaged.
さんによる
コメントを追加
3件の回答
ベストアンサー
The first thing I would do is remove the plastic covers and see if the console will power up using just the copper pad on the motherboard. I would also check the function of the disc drive using the copper pad on the disc drive board.
If all works well then it means that the metal pieces on the case is not touching the copper pad on the motherboard when the plastic case is installed.
I hope this helps.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
How would you power up using just the copper pad?
さんによる
Just plug it in and touch the copper pad with your finger.
さんによる
コメントを追加
The copper pads don't respond
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Follow my recommendation below
さんによる
コメントを追加
Did you (donnie96) find the solution by any chance?
Update (01/06/2019)
This cable is not plugged in all the way, check both ends of it. Let me know if you got it working, I had the same problem and just fixed it, thank god for blue prints!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
By the way it's under the power supply unit AKA: PSU
さんによる
コメントを追加
回答を追加する
donnie96 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 2,324
