メインコンテンツにスキップ
A portable Bluetooth speaker manufactured by Ultimate Ears.
60回答 すべてを表示
Why is my speaker taking 24 hrs to full charge?
I had my speaker and charger in my lunch bag...a bottle of milk spilled on the power adapter and shorted it and is no longer working.... When I charge my speaker without the original power adapter...it takes 10 times longer to fully charge....why?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Check the wattage of original charger. Just because it fits doesn't mean it will work correctly. For example some old iPhone usb adapters are only 5 watt. Or half an amp. Most likely you need a 2 charger for your tablet. Most larger phones even take 2amp now.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Actually, the UE Megaboom requires even more power.
It follows (USB Power Delivery)https://en.wikipedia.org/wiki/USB#PD specification (even if it doesn't use a USB 3 or USB-C connector).
If you look closely, in addition to the standard 5V 2A (10W) used by most tablet, the charger is also rated for 9V 2A and 12V 1.5A (18W, the later even able to word with thinner cables).
To charge fast the UE Megaboom, standard puny 10W tablet chargers aren't enough.
You should look for 20+ W chargers used for latest generation tablet computers/transformers and for laptops/ultra-books that charge over USB-C.
(You either need the charger to have a USB-A connector on the charger itself instead of a soldered cable or you need a USB-C to microUSB adapter).
さんによる
do you know this for sure? cause there also exists quickcharge specification which has similar voltages but isn't compatible with usbpd.
さんによる
コメントを追加
Usually the power adapter you are using has a low wattage. A 10.5 W connection (2.1A) may seem too low. A 15.5 W connection (3.1A) may be more helpful and upgrading to an 18 W (3.6 A) or 20 W (4A) connection may help with charging speed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It takes so long because the original charger is a very high-power charger. It's much more powerful than any other charger you're likely to have or find.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gary さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 7,705
