メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
The device identification can be found on the side of the headset.
36の回答 すべてを表示
Why are my beats only paring up and working while charging?
The beats will only work if they are connected to a power source, the Aux cable works perfect, but whenever i want to try the wireless mode it wont work, for example :
If the beats are being charge and i pair my iPhone it works and everything,but if I unplugged them from the charger it wont even turn on the Bluetooth
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
I have Zedd solo doing the same thing
さんによる
I have a Polaroid doing the same thing
さんによる
コメントを追加
3件の回答
選択されたソリューション
Two problems I would investigate:
1. is the internal battery dead?
2. loose connections with respect to the internal psu/battery
try opening one of the speakers - the side with the charger port. take a look at these images for some guidance
この回答は役に立ちましたか?
スコア 2
コメント:
Excuse me, but which pictures ??
さんによる
Ah sorry about that: Here are some links I just found
some of these images and articles are not specific to your edition but all speakers are constructed the same way, especially regarding power input and battery placement relative to speaker element (because of electrical noise from AC-DC-AC conversion and effects of relative distance and placement of electronics components on creating issues with use or the need for additional noise-reducing systems (which as you know, more things to subdue the symptoms could just mean more isolated malfunctions and harder to fix as there's no part to swap, when the entire system is degrading.)
let me know how it goes!
http://www.core77.com/posts/52314/A-Look...
http://www.head-fi.org/t/632063/dre-beat...
http://www.head-fi.org/t/688434/my-old-s...
http://gizmodo.com/are-beats-headphones-...
さんによる
please solved my problem.When I plugged it can be work.When I unpluggedit can't be work.
さんによる
コメントを追加
I have this problem just like when I plugged than it can be work.When I unplugged it can't be work.
この回答は役に立ちましたか?
スコア 0
コメントを追加
My only works when it’s charging but when it is not charging it doesn’t even turn when battery is 100 percent and I got them today
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
briantrevino さん、ありがとうございました!
統計データを表示:
過去 24時間: 19
過去 7 日: 104
過去 30 日: 448
今までの合計 18,952
