メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
317回答 すべてを表示
Mac Pro 2009 won't start up - solved
Hey, everyone.
I got a problem that my mac pro 2009 doesn't start up.
Yesterday, I use it but it shutdown suddenly.
Then I press the start button again and it boot about 15 sec then shutdown.
After this, I can't start up anymore when I press the start button.
I try to check anything following this http://tim.id.au/laptops/apple/macpro/ma...
When I plug the power cord, the OVTMP CPUA and OVTMP CPUB LEDs flash red.
Press the DIAG button, the 5V STBY LED illuminates
Disconnect the front panel board and momentarily jump the SYS_PWR, no any response.
Reduce computer to minimal configuration, 5V STBY LED illuminates.
But I still don't know which part broken.
Can anyone help me or tell me which part I can check?
Whether the OVTMP CPU A, B LEDs, and 5V STBY LED illuminating means the power supply and backplane board is ok?
Thanks a lot.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント:
Did you solve this problem? I'm having the exact same problem!
さんによる
yes!! I solved my problem. Finally, I can sure that my backplane board is out of work , so I replaced it ,and my mac work again.
さんによる
Thanks! I'll try to do the same!
さんによる
Hi, I am facing the same problem now. May I know what is backplane board? Is it the logic board?
さんによる
Yes, it's the logic board.
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
Since it looks to be mainly an electrical issue I'd suggest to see if you can manage to find a "tested-good" PSU to use with your mac pro. I recently had a similar issue and it helped I had access to 2 identical mac pros (both 2,1) to try and isolate the problem (sudden shut down after few min of use). Sadly in my case the culprit seems to be something on the motherboard, in which case isn't worth to try and figure out what as that would require time, knowledge and equipment (electronic diagnostic lab) that I do no posses or have access to.
Hope the above might help you point you in the right direction and best of luck with finding and solving the issue with your mac pro! :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hong Wei Li さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 2,623
