メインコンテンツにスキップ
A mid-range smartphone from HTC, released November 2014.
27回答 すべてを表示
Won't turn on - Orange blinking LED
Hi,
My HTC Desire 820 won't turn on. It was left unused during some time.
When I plugged it with the wall charger, the LED is blinking orange. I let the phone like this for 2-3 hours, unplugged it and try to turn it on, but it didn't work.
I opened the phone, disconnect and reconnect the battery, try to turn it on, nothing. Try to charge it, nothing.
I tested the battery with an multimeter, and it says ~3.9V. On the battery, it is written 3.82V
When I plugged the phone on my PC, a device called QHSUSB_BULK is detected.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
3 件のコメント
i have the same problem too instead it started yesterday by giving me a black screen and vib then i pressed the lock to turn it off then the led charger started to blink while it was off then it tried to open it again and it started then today it was like 90 % i mean the capacity of the charging and i went to get smth then i got bk finding it just turned off and wont start again :(
さんによる
Hello
yesterday my HTC Desire 820 camera works fine but once he blocked me on faccebook page. he does not want to answer. nor demrrer or anything. and then I look at the HTC website to solve the problem and I press the power button and
+ Volume and turn off my device but it does boot. also when I put the charger .it signed a red lamp remains like this
but it did not work. Tried holding volume button + power button for approx. 2 minutes, nothing happened.
When I plugged the phone to my PC, called QHSUSB_BULK device is detected.
you could help me
Thank you.
さんによる
i have the same issue going one, the notification led is blinking red constantly and screen has no response even recovery mode isn't working. i don't know which thing has problem. Battery is dead or PCB fault.
please comment if some one know about it.
さんによる
コメントを追加
15件の回答
最も参考になった回答
1 year too late but
This may help you:
Hold down "VOLUME PLUS" + "VOLUME MINUS" + "POWER"-Button at the same time for 10 seconds.
This should boot your phone.
Let me know if this helped anyone!!
このアンサーは役に立ちましたか?
スコア 11
6 件のコメント:
i have followed the instruction but nothing has happened
さんによる
It worked.. thanks
さんによる
Thank u for this advice bt i jst want to knw the reason behind this why the phone automatically get swicted off nd strt blinking a red kind of light in left side of screen
さんによる
it worked man.........
さんによる
i try it 3 more times, it worked
さんによる
1以上のコメントを表示
コメントを追加
I am facing same problem but on of my friend who is repairman of gadgets said that my charging board of htc is damaged.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
my phone black screen on...
led orange light blinking
device not switch on
plz help me
さんによる
コメントを追加
nothing is happening i have done this many times but phn isnt starting.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello there, i had the same problem with my phone ,most of the HTC smartphones have the exact problem of charging and the red light blinking . I took my 820 to the htc service center and they told me that the charging port was damaged and this is a common problem in many devices they gave me a bill of 3000 INR for replacing the port as well as the battery with one month warranty. but if you are low on budget and don't want to spend that much you can get both of them replaced at a local shop for 1500 INR. Battery costs around 700-800 while the port costs around 500-600.Your phone will no longer have any charging issues . believe me its no software problem .
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
htc desire charging connected red light blink
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
さんによる
I have same problem, my mobile is turn off and when it is plugged with charger, the orange light is blinking and do not turn on.
さんによる
コメントを追加
hello,maby this link it true and download xml repair dead boot htc 820n,maybe some guy here wants to try to buy this firmware and give it all to everyone would be of great help to many of as.
here is a link to this site who sells this repair htc 820n xml. unbrick rom; http://www.emmc-files.com/index.php?...t...
i dont know if it trust seller but it good to try,i dont have 10 $ on my credit card to try sorry.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi
HTC company. They Monopoly Software Many of you customers are looking online in RUU. They can not find it. How can the company provide (ROM UNBRIK - QHSUSB_BULK) We must throw our phones in the trash
And make us beg in the forums to search ROM RUU. As homeless
From now on, we will not buy their phones. We will boycott an HTC company.
share with your friends * thanks
さんによる
コメントを追加
i have the same issue with my phone it wont wont turn on and on plugging it to charger its led light just blinks the guy at service center claims to have checked it by connecting a new battery to it but it still wont turn on so he said that its motherboard is short circuited and it need to be replaced
my question is could it be really a problem with motherboard or something else Mother board will cost me almost 80% of the phone price
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
salam all friends if you dont try before so pls once try press volume up+ down + power button same time press this process 3 to 5 minute i hope your mobile is working just one try
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi I'm Anushke,
I'm using HTC Butterfly 3 Mobile phone , mobile is totally inactive when I inserts  the charger the charging indicator is blinking,if anyone know the reason of this matter,
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have HTC butterfly 3 it blinks red light 5-7 times please tell me solution I tried power + Volume up/volume down/both
さんによる
コメントを追加
salut
Société HTC. ils logiciels Monopoly Beaucoup de vous clients cherchez en ligne en RUU. Ils ne peuvent pas le trouver. Comment l'entreprise peut-elle fournir ( ROM UNBRIK - QHSUSB_BULK ) Nous devons jeter nos téléphones à la poubelle
Et faites-nous quémander dans les forums pour chercher ROM RUU. Comme sans abri
A partir de maintenant, nous n'achèterons pas leurs téléphones. Nous allons boycotter une société HTC.
partage avec tes amis *merci
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi my name is Aaron as my htc green title kept appear as it won’t charging when I go to factory reset it won’t do it and green htc title kept appear red light blink
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For my htc desire 820 they said that the motherboard is short circuited and will cost aloy of money to repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Htc red light flexing ka ky matlb charging k time ka
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It seems like your HTC Desire 820 is experiencing issues. The detection of "QHSUSB_BULK" suggests a problem with the phone's firmware or software. You may try to resolve this by flashing the stock firmware or seeking assistance from HTC support. If the issue persists, it could be a hardware problem, and professional repair may be necessary.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Skaaj さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 16
過去 30 日: 77
今までの合計 35,008
