Why my phone reboot or shutdown itself
hi, my phone is on sleep mode, when i turn on the screen it stay black after many trying to turn on the screen it reboot itself or shutdown any solutions !! thanks and sorry for my bad english
There could be several reasons for this. Maybe it is a Problem with your SIM Card or the micro SD Card. But at first you should do a Backup (with the Samsung Kies Software for Example) an Reset the Phone, then you can copy your Personal Files, Contacts etc. back up in the Phone.
If your Battery looks a little swollen you should not longer use it.
このアンサーは役に立ちましたか?
thanks for your quick reply, i already replaced the battery and reset the phone i also flash new stock rom via odin but the problem is the same :(
So you flashed a new stock ROM?
Now i was wondering, did you flash the firmware before or after the factory reset?
このアンサーは役に立ちましたか?
first i do a factory reset then the phone work just fine for 6 hours and the problem back again
then i flash the stock rom (sammobiles) the phone work fine for while and the same problem back again
Hmm...... so even if you would do a reset, the problem remains right?
I guess that you are running version Jelly Bean version 4.2.2.
Please take a look at the battery information screen and look at the running processes, is there anything that stands out? Like for example heavy usage google services or something.
Normally the screen should have the most usage and after that Android OS itself.
There should be something inside your phone which is causing that issue, since you already replaced the battery.
As for the battery, is it an original samsung battery?
yes android version is 4.2.2 , i already check battery information, actely after flashing i have not installed any app even i don't setup the google service the battery is original from a local samsung store, i am really confusing because i can't see if that a software or hardware problem :(
Hmm..... okay, try and wipe your cache partition.
Maybe there are still some remnants of the previous os which could cause problems.
It won't hurt to try, since there's nothing to lose at this moment.
When that's done, observe your phone for at least 24 hours.
How old is your phone btw?
thanks a lot, i already try that, i have the phone at least half year now
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 122
