What can I use to stick back together the mouse?
I disassembled the mouse to fix the bent aluminum from dropping it and it works, but sticking the bottom part to the plastic battery tray is hard. What is strong enough to hold the plastic and alunium together?
2 件のコメント
Do you mean the entire bottom panel, or the battery cover? Refer to the Magic Mouse teardown guide and tell us which step number illustrates the part you're trying to reassemble. Step 3 or Step 6?
David Spalding さんによる
The battery cover is OK, what I meant is the bottom panel https://d3nevzfk7ii3be.cloudfront.net/ig...
step 6
Vitaly Bugaychuk さんによる
