I took apart my vacuum and now it's not working.
The roller brush wasn’t working, so I took the vacuum apart and cleaned it. After I put the cover on the switch, the vacuum wouldn’t turn on.
If your Shark Navigator Lift-Away Pro refuses to turn on, use this Shark Navigator Lift-Away Pro Won’t Turn On problem page for possible causes and solutions.
このアンサーは役に立ちましたか?
I tried the options in fixing the machine .... but none work. I tried calling the help desk and they never returned my call ..... help !!
It could be overheating unplug and look for clogs clean filters with lukewarm water let dry completely replace filters wait 45 min and plug back up that will keep ur shark from overheating
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 7
過去 30 日: 43
今までの合計 983
