メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
What is my iPhone dying so quickly
When using my iPhone I usually charge my phone to 100%. However my phone tends to die around 70% to 90%. Then after a few minuets I turn it on to find it at around 70% to 90%. When it's not connected to a charger it would turn off right after the device has been powered on. i drained the battery but it would again power off if no charger is connected to the phone. I was wondering if I should buy another battery for the iPhone 6?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Hi Eric
What may be beneficial for you is to contact a Apple Support Rep and get them to run diagnostics for you.
If your battery fails, then you can consider replacing the battery.
It is a common misconception that it is "good" to discharge your iPhone battery , lithium-ion batteries found in iPhones should not be discharged to the point of zero, it will shorten the battery life of your iPhone.
Regards
Brayden
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eric Del さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 120
