Why won't my washer drain
It will run through the wash cycle and stop and not drain the water then I can turn it to the rinse cycle and run it again but stops a quarter way btween rinse and spin and still won't drain the water
Cause 1
Drain Pump
The drain pump uses an impeller to force water through the drain hose. If the drain pump motor is not working, the dishwasher won’t drain. To determine if the drain pump is defective, check the pump motor for continuity using a multimeter. If the motor does not have continuity, or if is getting power but won’t run, replace the drain pump. Drain pumps are not repairable—if the drain pump is defective, you must replace it.
Cause 2
Drain Impeller
The drain impeller pushes water through the drain hose and into the garbage disposer or drain line. If the impeller is broken, replace it.
Cause 3
Drain Solenoid Kit
The drain solenoid opens the drain valve to allow the water to exit the dishwasher. If the drain solenoid fails the valve will not open causing the dishwasher not to drain.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,546
1件のコメント
i have the same problem with my Kenmore 90. it hasnt oveflowed yet for me and ive had it for a month
oi dont know how to fixit other than just keep using it
john guy さんによる
