Why would not the image fit the display?
The image displayed on the monitor is of centered and/or does not fit it's size.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If the monitor is connected to the PC via a VGA connection, have you checked the resolution rate of the PC's graphics adapter card is compatible with the monitor?
Here is a list of the supported resolutions.
Again if you are using a VGA connection, have you tried using the monitor's OSD Menu options to centre the display and also to fit the screen?
Here is a link to the user guide for your monitor. Scroll to p.4.3-4.4 to see how to adjust the settings.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
