メインコンテンツにスキップ
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146回答 すべてを表示
Can you replace the rear fingerprint sensor/power button?
According to a few users
https://www.reddit.com/r/lgg5/comments/4...
Including myself, I have noticed that the G5's rear button is kind of wobbly and makes a clicking noise when you tap it. Can this be replaced or tightened up? Thank you for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
As you have stated and reinforced by the links you provided, it sounds as if a production run of these devices were not given a quality control final check. This does happen often on phones, and you can replace them but only within the 14 day period (if you got it from a carrier), but if you are beyond that time frame then you will need to contact LG about it.
However, it is possible to replace nearly everything on the G5, and this does include the buttons. Take a look at the photo provided in the iFixit teardown: https://d3nevzfk7ii3be.cloudfront.net/ig...
On the left, you can clearly see that they have removed the fingerprint scanner. This replacement is possible but I would not go through all of that work just due to a rattle. If the rattle became worse and the button started to slip or give inaccurate readings, then I would contact LG for a warranty claim. If you do the repair yourself or have a repair shop do the repair for you, it is possible to tighten it up if it is still a bit loose. Each person would have their own opinion on how to complete this task but it is possible. Yet again, I stress that if it is just a mild annoyance and does not impact the use of your phone, just deal with it--or contact the carrier or LG to get a new device--but I would not attempt the repair to fix something that is not broken.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also have problems where I'm having to press the button alot harder to wake and close the phone, maybe something has gotten behind it. Time for a tare down video search.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,743
