メインコンテンツにスキップ
Samsung Galaxy Note 5は2015年8月に発売されたSamsung製のスタイラスペン付きファブレットスタイルのスマートフォンです。
259回答 すべてを表示
fingerprint doesn't work anymore I forgot backup password
My fingerprint doesn't work anymore and is asking for my backup password but I forgot it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメント:
If it's anything like the iphone you may have to reset your phone.. does it give you the option to change your password?
さんによる
コメントを追加
2件の回答
最も参考になった回答
i want my backup password
このアンサーは役に立ちましたか?
スコア 1
コメント:
I want backup password
さんによる
コメントを追加
Samsung’s fingerprint sensor does not work 100% all the time. Sometimes, even a tiny speck on the screen or on the finger can lead to misreading. After several attempts of unsuccessful logins, usually five, the device will then ask you to enter the backup password.
There are two things that you can try to regain access to your phone.
1) By forcing the phone to ask for the registered Google account. This can be done by entering the wrong password 20 times. Once the popup shows asking for the Google account, make sure that you enter the correct credentials. Keep in mind that a Google account does not have to be a Gmail account. It can be a third party email with a separate password. If you enter the correct credentials, the device will be unlocked and will ask you to enter another password.
2) If you are unlucky and also forget the Google account credentials, the only way out is by performing a factory reset. There’s no other way than this. As the name suggests, the device will be restored to its factory state, which means everything will be deleted from your device’s internal storage,
For reference, here are the steps how to do a factory reset:
  • Turn off the device.
  • Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key.
  • When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
  • When the Android System Recovery screen appears, release the Volume Up and Home keys.
  • Press the Volume down key several times key to highlight ‘wipe data / factory reset.’
  • Press Power button to select.
  • Press the Volume down key until ‘Yes — delete all user data’ is highlighted.
  • Press Power button to select and start the master reset.
  • When the master reset is complete, ‘Reboot system now’ is highlighted.
  • Press the Power key to restart the device.
このアンサーは役に立ちましたか?
スコア 0
コメント:
@v3nuo
You are coming very close to get some repercussion from your habitual spamming. You are always linking to the same site which makes your answers spam. Be advised!
さんによる
コメントを追加
回答を追加する
Esperanza Rodriguez さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 63
今までの合計 1,897
